Arlo Light doesn't turn on with schedule
  • 2 Replies
  • 1510 Views
KimNguyen
I purchased arlo light, set up and schedule when the front light turn  on, but it didn't .  I noticed on my phone, there is rectangle (turn on/off).  Should it be off? if it 's off then the schedule is not working.  HELP!!
Thank you
Thank you
The light is like the cameras... tho it is ON, the light comes on when motion is detected only...
The switch to turn on and off the light is a manual mode... toggle on and it will stay on for the time set ( in settings, default is 5 mins IIRC )
Also, you may need to increase the motion detection sensitivity in your modes/rules. And don't forget that there's an ambient light sensor in the light so it won't turn on when there's enough light. Use the Dusk to Dawn Sensor adjustment in Settings, My Devices, your light to help with that if needed.
  • 2 Replies
  • 1511 Views
