Arlo Light Bridge model ABB1000 not follow schedule
I have two issues: 1. The arlo bridge time zone always changed to UPC-08:00 no mater which time zone I set, it will return to UPC-08:00. Why? 2. The lights do not follow the schedule for arm/disarm. Example if I set to arm from 19:00 to 07:00, after 08:00 it still showed armed which suppose to be disarmed. If I go to schedule change the time to 18:00, saved it and then changed back to 19:00 then the mode is correct, the bridge showed disarmed, but next day if is armed again after 08:00 I only want the light to be armed during the night and disarmed during the day . Running on Android V 5.0.3_28739 Released 10/1/24
Message 1 of 2
832
Please reach out to the Support Team to further investigate this symptom you are experiencing. You can find several options for contacting support through the Arlo Mobile App by navigating to Settings/System/Support.
Message 2 of 2
794
