When I click on the " + " or " ... " the objects begin to move but once I click on one the entire area freezes and I have to log out.
Dashboards are device specific, the changes you make when logged in to your account will not transfer to a new device. This is by design.
A cloud fix was released that should resolve the issue with adding or adjusting widgets within the dashboard when logged in to the web client. You will need to clear your browser cache and then try again to see if you still experience the same behavior. Please let me know the results.
"Online" as in using a web browser? Have you cleared cookies/cache and tried a different browser?
I'm having the exact same issue. I've tried it on Chrome, Firefox and Edge and have the same issue.
I haven't but then my interactions with support have been, let's say, less than good.
Also, I don't see the options you're talking about on my dashboard. This new interface is absolutely horrible, to be honest.
It's different for sure but it just takes a bit of time to get used to.
Maybe a screenshot of your display would help. There's no icon at the top left of your screen that you can click on?
duplicate
Ah, I see - you're using the web interface which didn't register - sorry. In this case, use Settings (bottom of the choices on the left of the screen)
I'm not able to replicate any issue with adding or moving the widgets on the dashboards screen.
If you clear your browser cookies/cache do you still experience the same issue?
It wouldn't be an issue with cookies since I've tried it with 3 different browsers and, now, on two different machines (home and work). However, I did clear them and it didn't help at all. As soon as I click add this is all I see and nothing responds except the back button.
And then what? The links just go to the main support page and community just goes to here. None of the options bring up devices.
Use the app instead.
The dashboard looks completely different on the app. It was the first thing I tried.
Click on the profile icon in the upper left of the app, and you will see the support center there.
That's a really roundabout way to get to chat.
Oh wonderful. They told me to clear the cache and log back in on my browser...
Which logged me out of the app on my phone and killed chat...
I see various issues. I tried adding a widget and the default size was too large so selected the small version. That changed the size but there's no thumbnail in it. Moving it didn't change anything (maybe because it's the only one?) so I clicked on Done. Still no thumbnail so tried to delete it. I get a blank box and can't cause anything to happen.
This is what I've been experiencing this entire time.
I think support has given up on this issue. I haven't heard anything from them since the 1st.
For those experiencing this issue, do you see the same behavior if you try to add or adjust widgets within the dashboard using the mobile app?
@JamesC wrote:For those experiencing this issue, do you see the same behavior if you try to add or adjust widgets within the dashboard using the mobile app?
No. The mobile app works (at least on Android) however, that dashboard is not the same as the web dashboard. Changing it doesn't change the web version.
@JamesC wrote:Dashboards are device specific, the changes you make when logged in to your account will not transfer to a new device. This is by design.
It's now working for me. Thanks so much!
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
