Temporarily disarm one camera
How do I temporarily disarm one camera using this new Arlo Secure app? I used to be able to go to "Mode" and just click a camera to disarm, then turn it back on a little later. That option seems to be gone. The case is, for example, a maintenance person shows up to work on something in the back yard, and I want to turn that single camera off so it's not constantly triggering while they're out there. Then 15-20 minutes later I want to just click it back on. The only thing I can seem to find is all on or all off...I want to keep everything on except the one camera in the zone that is temporarily experiencing excessive motion. The constant alerts are annoying and it uses excess battery on the camera to just leave it run.
To temp turn off one camera...
go to Devices
pick/click on camera
click on Gear for camera
toggle Device ON/OFF ( first line )
camera is temp off till toggled back on
Another way that I've been using is to go into the rules for the current mode and just disable motion detection. That doesn't remove the rule or any settings associated with it so you can then go back to the rule and enable it later.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
