  • 4 Replies
  • 4029 Views
YpNo
Hi,
I've tried to use my own program to follow if I have an active stream and, if there is, getting the stream URL.
I've found a way to know if there an active live stream but I didn't know how to retrieve the stream URL.
Could you help ?
ShayneS
@YpNo
Can you provide more detail regarding the issue you are experiencing?
YpNo
Hi,
It is not really an issue. Just a needs or information.
I've tried to use Arlo's API to get some informations in a python script. I want to loop on my cameras to know if I have an active stream, and if yes, get the stream url watch it on VLC.
For example I know that the arlo's api call path for starting a new stream is "/hmsweb/users/devices/startStream" on myapi.arlo.com . But I did find out the api path url to get if there is an active stream and get the stream url of the active stream.
Is there api endpoint for getting stream status and url ?
Regards.
YpNo
Hi,
Any help ?
Edinburgh_lad1
Hero
Hero
You're in the wrong forum, pal. Since it's an Arlo forum, you'll not get this kind of info here.
