Setting up 'mode'
  • 4 Replies
  • 2462 Views
Valyc
Hello,
Recently bought some Ultra cameras, but I am struggling a bit to set the modes and rules up to my needs. I therefore hope that you would be able to assist me in how to set it up?
Here are my requirements:
- The cameras must record when I am not home (Geofencing).
- But not in a certain timeframe each day, when the nanny is at my home with the kids.
- The outside cameras must record from 11 PM to 6 AM every night.
Right now I have set it up like this:
- Have chosen Geofencing as my base mode.
- In Geofencing I have chosen Schedule in both home/not home.
- In Schedule I have made a Night timeframe.
But I do not know how to setup the cameras not to record when the nanny is here (ie from 2 PM to 5 pm).
Hope this is an easy fix! ☺️
Do you see "Library" in your app menu?  Or do you see "Feed" and "Dashboard" instead?
Just to make sure I get this -
  • indoor and outdoor cameras all armed when you are not home
  • no cameras armed when the Nanny is there (2 pm to 5 pm)
  • only outdoor cameras armed at night when you are home
What cameras do you want armed when you are home but the Nanny is not there?
Valyc
Hello StephenB,
Yes, I have 'Library' at the bottom of my app. 🙂
Yes, that is correct:
  • All cameras armed (both inside and outside) when I am not home.
  • No cameras armed when Nanny is there.
  • Only outside cameras armed at night when I am home
  • No cameras should be armed, if I am home during daytime.
This summary isn't quite right, I think it's actually this:
When I am not home
  • All cameras armed between midnight and 2 pm
  • no cameras armed between 2 pm and 5 pm (weekdays?)
  • all cameras armed between 5 pm and midnight
When I am home
  • No cameras armed between 6 am and 11 pm
  • outdoor cameras armed between 11 pm and 6 am.
This is a problem with Library, because you need two schedules to accomplish this - one for "home" and one for "away".  Arlo only lets you have one schedule.
Your options are to either
  1. leave outdoor cameras armed all the time when you are home.
  2. leave all cameras armed all the time when you are not home.
Either change results in only needing one schedule.
Valyc
Yes, I also concluded that I was missing a second calendar in order to use the cameras as i wanted.
Anyways, thanks for your assistance 🙂
