Is it possible to set different notification sounds to different cams in Android Arlo Secure?
The version I have is 4.5_28538
Either within the Arlo app or in Android Notification Settings in App Settings?
This is quite necessary for me to have.
There are 4 cams all connected by WiFi and no base. Thanks!
Thank you for a prompt reply.
It's not the reply I was hoping for tho. My front door camera needs to give me a specific sound so that I know someone is there. And the indoor cams need to be silent as far as notifications are concerned although they need to log and record people movement. And you say this isn't possible. That's a horrifying way to make an app. Cams have different functions in use. Some need to just keep track of activity. Others can be required to provide specialized notifications to let the user know something requires attention. Having everything give the same notification is absurd. I won't bother troubleshooting my cams any further and will request a return. Someone really s*rewed the pooch on this one. Thanks again.
Nope. Individual camera notifications aren't possible.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
