Playing dog's bark on two chimes
  • 4 Replies
  • 378 Views
  • 2 Likes
Edinburgh_lad1
Mentor
Mentor
To rub salt to the wound, when one specifies routines and actions, there's an issue with playing a sound. If you want to play a dog's bark or any other sounds on two chimes, the app crashes.
The Dev Team should be ashamed of releasing this keech (= Scottish word for sh**).
ShayneS
Hi @Edinburgh_lad1
Can you provide the steps to replicate this symptom as well as the app versions you are running?
ShayneS
@Edinburgh_lad1
Can you send a recording with only one chime selected as well?
ShayneS
Thanks,
I provided all the info to my team and they are reviewing.
ShayneS
Symptom could not be replicated. Which version of the app are you using now?there have been a few updates. I don't see any chimes attached to this email, which model chimes are you using?
