Notifications sounds
iOS Current
iPhones 15 plus 2 of them
arlo secure app Current
the audio tone for mode changes is not working at all. The notification banner works but no sound
odd part is, when armed and a camera detects motion and records, both banner and tone notifications work as expected.
sure would be nice to see this acknowledge by Arlo and a remedy solution provided
Hi @pcs0snq
Thanks for the feedback. Are you saying that when you manually switch the modes within the dashboard screen with the buttons at the top, you get the notification pop-up, but that notification does not have an audible sound?
I'm not able to replicate this on the latest version of iOS with iPhone 16 Pro Max. Can you try removing and reinstalling the Arlo app and test this on another device as well?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
