Hello,
I use Arlo now for 2 months and I am pretty sure that in the beginning, I was able to choose (for each seperate cam) for what event type I would get a notification. There, I could turn off "animal" and "movement", but keep "person" turned on. This possibility s gone now, or I cannot find it anymore.
The point is that I have cats and now I get notifications the entire day because my cats walk around. I can hide the recorded videos in the feed, but it only hides the videos. The notifictions keep coming which is annoying.
Does anyone know if I can still turn off notification for animals only, but keep notifications for "person" turned on? And if so: where in the app can this be turned off?
I am using the app on Android, version 4.6.1_28552
Hello, thanks for your reply. Indeed I have a subscription. It took a while but finally I found where in the app these options can be set!
Do you have a subscription? Smart Notifications requires a sub to work, along with cloud recordings.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
