No full-screen mode for live view on Android v4.7_28565
  • 8 Replies
  • 3814 Views
EffarigLlavud
When I view the live feed for any of my cameras on v4.7_28565 (Android) the icon to expand the view to full-screen is missing. I cleared cache and even un-installed/reinstalled the app with no success.
Please help. The live feed is way to small without being able to go to full-screen.
EffarigLlavud
Forgetting and re-adding the cameras seems to have done the trick.
8 REPLIES 8
If you mean live view, I see a double-headed arrow in the top right of the camera view. I'm using the new user interface (UI) that uses Feed to view recordings. If you're using the same UI, go to Devices for live viewing on the camera to see this or, in Dashboard, be sure to use the large widget so you get the arrows.
EffarigLlavud
Thanks for the suggestions jguerdat, unfortunately I don't see the double-headed arrow under Devices when viewing a live camera feed. The only icons that appear are the microphone, record, and camera icons.
As mentioned, I'm using the latest Android version of the app. In this version, the primary app buttons are Devices, Library, and Mode.
The doubleheaded arrow icon used to appear in this live view at the top right like you're seeing. For me, it is now missing.
This may be due to use of the old UI that uses Library to view videos. I can't verify that since I'm on the new UI.
@JamesC or @ShayneS , can you verify that the old UI is lacking the ability to expand live view to full screen?
ShayneS
I was not able to replicate this issue, does this occur on any other Android devices by chance?
EffarigLlavud
Not sure. I don't have another Android device to test. This repros on a Samsung Galaxy Note 20 Ultra, even on a fresh install.
ShayneS
Which version of Android are you using? I couldn't replicate on an android device when testing.
EffarigLlavud
Android 13. OneUI 5.1
EffarigLlavud
