At work, I have a Samsung Galaxy Tab A7 running Android 11 at work and I have it connected to the internet via a USB to Ethernet adapter, which works perfectly for every app on that device...except Arlo Secure. I am currently running Arlo Secure 4.12_28637. When I go to log in on the app, I get the error message " No Internet Connection", even though I do have a functioning internet connection through ethernet. No other apps on this tablet have any issue retrieving or sending data over the wired USB/Ethernet adapter, just Arlo. I need this tablet to stay connected and up on my desk so I can monitor those cameras as I work, but I can not have it on a Cell signal that does not exist in our building, or on a Wi-Fi network that is already heavily burdened by well over 100 connected devices. Is there something I am missing to get this to work?
iOS app is down for me as well.
Are you able to log into my.arlo.com on your work PC? It is possible that your company firewall is blocking the connection.
Although I get the "overloaded wifi" part, I still suggest trying the wifi as a test.
I am able to login to Arlo on the website on both the tablet and my desktop. It's actually a company Arlo account, so it has been Whitelisted, I just don't want to put it on the Wi-Fi permanently or have it open constantly on my desktop. But, yes, I can login to the website on both devices. It is just the actual Android app that says I do not have an internet connection when I do.
Can you try restarting your phone? Also check your data settings and make sure everything is on correctly for the Arlo app. Have you tried reinstalling the Arlo app on the Android device? If not can you please try that as well.
						Activity Zones1
						Applications mobile et en ligne2
						Arlo 4.1 App release notes1
						Arlo app1
						Arlo Mobile App351
						arlo not working2
						Arlo Pro 51
						Arlo Pro 5S 2K1
						Arlo Secure1,202
						Arlo Secure 4.02
						Arlo Smart115
						Automation1
						Before You Buy86
						cameras1
						custom modes2
						Features145
						Friend1
						Geofencing1
						Grant Access1
						IFTTT1
						Installation59
						Modes and Rules1
						my.arlo.com1
						notifications2
						Pro 5s1
						Security System App1
						Smart Subscription1
						Temporary disable1
						Troubleshooting379
						Vacation override1
