Micro SD card
  • 1 Reply
  • 5868 Views
StanLipiec
What are specifications for a 5000 hub  for micro sd card
https://kb.arlo.com/000062124/How-do-I-record-4K-Arlo-videos-to-a-local-storage-device
  • Arlo recommends that you use a microSD card with a minimum of 16 GB capacity, Speed Class 10, UHS1, V10.
  • The Arlo SmartHub supports up to class 10 UHS-3 V90 class microSD cards.
The cards are formatted as FAT32 (normally done in the smarthub).
The max size of the card is a bit unclear.  2 TB is potentially possible, but I haven't seen any posts here from people using cards that size with success.  Part of the puzzle is that a lot of cards over 1 TB are scams.
Generally I suggest staying with the 128 GB - 512 GB range.  128 GB holds about 100 hours of Ultra recordings, and normally my cameras only produce a few minutes of recordings each day.
