Laser or LED disabling motion sensor
We have deployed several ARLO cameras and a hub at our vacation home in the mountains as someone was messing around on the property when we are not there.
However, lately, we have had the cameras go "dumb" right after someone has shined a blue light (led? laser?) at the camera and then it doesnt record for about three to five minutes. WHAT THE HECK?
Any filter for this sort of thing? Camera case, or firmware update?
Buy a trail camera and hide it to cover the area to see what they are doing after the intrusion.
If you have a subscription, you might want to contact support to follow up. I'm tagging @JamesC and @ShayneS in case they want to facilitate.
It sounds like you are thinking the intruder is blinding one camera - somehow temporarily disabling the PIR sensor. It's not clear from your post whether they are disabling the others (or how). If they are getting to the hub they could simply turn it off; or otherwise cut the power.
One work around is to get camo skins to make them harder to spot, and then moving them to different positions (since the intruder obviously knows where they are).
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
