Invalid Factor Data
Hello,
Since im unable to find a support mail or an option to write a ticket, ill write a post instead.
Im locked out of my arlo account because the two factor authentication doesnt work.
Im forced to relogin into my account, followed by a code authentication which always fails. The only other option is selecting the same email and try again with also always fails, obviously.
Is there any known fix for this?
Are you saying that when you select "another verification method", and then choose email, that you don't receive a code?
Or are you saying that you do receive a code with both verification methods, but the app doesn't accept the code???
I am saying that the normal verification and the email verification are both the same. Both send me a code and both dont work.
I'm tagging the mods - @BrookeN , @JamesC , @ShayneS - to call their attention to your issue. They can create a support ticket on your behalf.
I have reached out to support regarding the 2FA behavior you are seeing. Support will reach out to you as soon as possible.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
