Aust
I am having trouble with the new App - I am trying to set up a schedule and geofence. What does the first step 'Always enabled' even mean? I just want to set up a simple schedule and then a geofence to activate at times as well. Sorry if it is a dumb question - it was so easy with the old app
It means that the automation is enabled no matter what mode (arm away, arm home, standby) the system is in.
This post from @Jeffi has screenshots that might help:
Thank you. I will give this a go
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
