  • 757 Views
dazednconfuzd
How do you make the app stay on arm away when you’re gone? Mine keeps switching to schedule when we’re gone.
Turn off the two schedule automations in Arm Away
dazednconfuzd
Thanks Stephen I’ll give it a try.
ittroll
Luminary
Luminary
I made the same mistake when first away for a few days. A scheduled kicked in and disable the system. ☹️
With the old experience you could select fully armed or one of any number of custom schedules. Fully armed was a rock solid security setting. With the new experience, the schedules are applied to 3 fixed modes. Which means you have to remember to make manual edits to your modes/schedules should your normal home/away patterns change.
Unfortunately, the limited modes of the new experience can lead to a comprise in the security of your home.
Arlo Wire-Free, Pro, Pro 2, Go, Q, Q Plus, Baby - You will continue to have access to free 7-day storage even if they enter the EOL stage.
