Arlo Sercure for IOS, Setup Geofencing
  • 2 Replies
  • 1307 Views
BDA28
When trying to setup geofencing, the automations for leaving and arriving both show a heading of "Arrive". See attachments. Could this be the cause of the mode not changing to "Arm Away" when I leave?IMG_2784.jpgIMG_2783.jpg
Nope, it's just a label. Click on the label for the Leave automation and edit it as desired. When setting up the automation initially you could have changed the label then. I don't know why or when this procedure changed from easily setting up separate Arrive and Leave automations which made things obvious and set the labels automatically to the current scheme but it sure causes confusion.
BDA28
Thank you for the reply. I will see if I can edit it.
You are absolutely correct. The setup process is very confusing.
It would help a great deal if there were some samples of typical setup screens.
