  • 8 Replies
  • 1400 Views
TheSungeon
I have Arlo Pro 2 and VMB4000. All of a sudden the entire system shows offline. I remotely rebooted my router and no change. The hub is connected to WiFi as I can see remotely accessing my router but entire system shows offline on the app. I am 400 miles away so cannot troubleshoot on-site. What could possible be the issue?  If it was a camera battery issue the hub would still show online. Help!
8 REPLIES 8
BrookeN
Are you still seeing this behavior? It appears that the hub and the tow Arlo Pro 2 are online. However the Pro is offline. That device may need reset and then re-added to the account.
TheSungeon
Yes the issue is happening again!
I can log into my router remotely and see the job is operational with power and internet but I cannot view my cameras as they say offline
TheSungeon
ALSO - what is weird is I get alerts when motion is detected but am unable to view cameras or feed.
Try removing one camera from your account and sync it again. Did  that fix the issue?
TheSungeon
I am 400 miles away
BrookeN
They are all showing offline now including the basestation. It appears they are going to need reset. Do you have a family friend or neighbor that is able to reset those for you perhaps?
TheSungeon
NO - it is a second home.   The base station IS ONLINE as I can see that remotely via my router.  AND I AM RECEIVING NOTIFICATION OF MOVEMENT DETECTION but I am unable to view.  Base and cameras show offline ONLY ON THE APP apparently.
BrookeN
One of the cameras will need to be removed from the account and then added back on. That should resolve the behavior you are seeing.
