I've read other similar posts, and they weren't helpful under my use case.
I tested the next mode concept. I enabled the Standby Automation Schedule under the Mode tab for the next desired mode alone, and I enabled the Arm Away Automation Schedule under the Mode tab for the next desired mode or action.
It seemed to work. So, this has been resolved for now. Thank you, StephenB!
Frankly, my suggestion is to leave the enable/disable alone (ie, leave it as Always Enabled). While I'm sure there are situations where using those is valuable, I don't use them and my schedules and GF work fine.
Thanks for your feedback. In the past, I tried your suggestion under the Modes tab, but it didn't work. You need to enable the schedule automations that will apply to that one mode, in my case, Standby. If I enable any other schedule available under Standby mode, then they'll cancel each other out, and nothing will be triggered. See Screenshot.
In my opinion, the Arlo App. modes and automations segments aren't well-written.
No, that isn't right.
If you are switching to a new mode in an automation, then the automation needs to be enabled in the modes you are switching away from. Not the mode you are switching into. For example, if you are switching to standby in an automation, then that particular automation doesn't need to be enabled in Standby, but it needs to be enabled in either Arm Home or Arm Away (or both).
If you want the schedule to be automatically suspended when you are in Arm Away, then you cannot just leave all modes enabled.
You could choose to manually disable the automations in Arm Away until when you return, though that is a bit of a chore (and easily forgotten).
I'll test the away-from-mode into next mode concept tonight, and I'll let you know.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
