- 2
While 5.5.1 disappeared for update for some time, 5.5.2_28806 has been pushed out!
Same question: has anyone updated to it, what bugs does it fix? Does it fix the following outstanding ones?
- geofencing not working all the times
- cannot pause playback of (locally?) recorded footage
- (any more?)
Alex
I got the same issue. Arlo's support is terrible. Arlo always changes firmware and software not to make things better but just to take money from customers, forcing customers to pay for Subscribe. Currently, I can't review videos saved on Local Storage, but I don't get any help from Arlo. Every time Arlo upgrades it makes it more difficult for customers to use.
@hotuonghung wrote:I got the same issue. Arlo's support is terrible. Arlo always changes firmware and software not to make things better but just to take money from customers, forcing customers to pay for Subscribe. Currently, I can't review videos saved on Local Storage, but I don't get any help from Arlo. Every time Arlo upgrades it makes it more difficult for customers to use.
I can see local storage here. VMB5000 here. What's yours? Have you been able to see local recordings before?
Alex
My Arlo Android app is 5.6.2_28827. Before I can see my local storage but after the update to this version I can't see more. My base station is VMB5000r6.
@hotuonghung wrote:My Arlo Android app is 5.6.2_28827. Before I can see my local storage but after the update to this version I can't see more. My base station is VMB5000r6.
this is scary. What's the symptoms like?
(think I'll stick to my current 5.6.1 at this stage)
Alex
You can't see anything from the local storage, only error messages show like the picture.
can't see the pic above. @StephenB / @jguerdat are you able to approve it please?
Alex
Unfortunately, this is not a new symptom.
Is this happening when the phone is connected to your home wifi? Or is this happening only when you are remote?
If this is happening when you are remote, then if you use port forwarding you should check the local LAN address of the smarthub. If that has changed, you need to update your forwarding rule. (Also, look into reserving the IP address in the router settings - most routers have a way to do that).
Two other easy things to try are:
- Ejecting the storage using the app, and connecting it to a PC. If the PC offers to "repair" the storage, then let it. Then check if recordings are actually being stored (or not).
- Uninstalling the app, and then reinstalling it.
A much more painful step which often will work is remove the cameras and smarthub from the account, doing a paper-clip reset of the smarthub and then adding everything back.
@StephenB wrote:
@hotuonghung wrote:Currently, I can't review videos saved on Local Storage,
not too sure if above are @hotuonghung 's root causes. Note that he has been successfully playing local recordings, until update to 5.6.2
Wondering if there are other users with local recordings and recently updated to 5.6.2 too? Do you experince the same as @hotuonghung ?
Alex (5.6.1)
Alex
hi @JP-FR , is this the same as your issue? @hotuonghung has been accessing local recordings successfully, until 5.6.2. Have you ever been successful in accessing recording, before?
Alex
Well, this particular symptom has shown up for some users for several years now. And it did happen to me a while back (before "Feed"). The suggestions I made (other than the paper-clip reset) are both safe to try and easy to do.
I am not seeing this symptom with 5.6.2 on my iPhone.
@alex_looYes it's the same issue,
like @booxman said here https://community.arlo.com/t5/Arlo-Secure/ARLO-android-app-5-5-3-28810/m-p/2441619#M12250%3Fcid=1024... : assume that the dysfunctionality that is going on is intentional.
I'm moving to another brand.
- 2
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
