My device seems to keep going offline, giving me the message " Your Arlo device appears offline".
Is there a way I can check how much battery strength it has? I have an internal battery, that is plugged into outlet power.
@Hinch wrote:
I have an ARLO GO outdoor camera.
VML4030-1VZNAS – Arlo GO Mobile HD Security Camera
That connects using mobile data - and doesn't use your wifi. Verizon is the service provider in your case.
There could still be a cellular dead spot there. If you have a Verizon phone, you could check your mobile data at the same location as the camera.
What device do you have?
ARLO Smart
@Hinch wrote:
ARLO Smart
That is not a device, it is an old subscription plan.
What device is going offline? A camera? A base? Either way, what model.
I think the issue is that wifi service is not good on that side of the house. I took the camera inside the house and it worked fine, and then I could see the battery strength through the app
Often that is the case.
Thank you for the education that "Smart" is my subscription plan.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
