  • 7 Replies
  • 1905 Views
Hinch
My device seems to keep going offline, giving me the message " Your Arlo device appears offline".
Is there a way I can check how much battery strength it has?  I have an internal battery, that is plugged into outlet power.
@Hinch wrote:
I have an ARLO GO outdoor camera.
VML4030-1VZNAS – Arlo GO Mobile HD Security Camera
That connects using mobile data - and doesn't use your wifi.  Verizon is the service provider in your case.
There could still be a cellular dead spot there.  If you have a Verizon phone, you could check your mobile data at the same location as the camera.
7 REPLIES 7
What device do you have?
Hinch
ARLO Smart
@Hinch wrote:
ARLO Smart
That is not a device, it is an old subscription plan.
What device is going offline?  A camera?  A base? Either way, what model.
Hinch
I think the issue is that wifi service is not good on that side of the house.  I took the camera inside the house and it worked fine, and then I could see the battery strength through the app
Often that is the case.
Hinch
Thank you for the education that "Smart" is my subscription plan.
