  • 7 Replies
  • 298 Views
  • 6 In Conversation
rlmckeen
It appears I'm not the only one with this issue, but I'll list it here in the hopes of getting a solution and maybe placing it here so someone else can Google it.
I can sign into the app and my username and password work. However, the 2FA screen requests a six-digit code which is never delivered to my email address. I'd choose a phone number for an SMS, but I never get the option. The app and the website both list my email address as the only three options. The same email address, three times and none of them work.
Better still, I try to use the chat as instructed to check on my support case after 24hrs. 48 hours later and the chatbot says I'm not entitled to any support and won't connect me. No matter if I put in my case number, the engineering support ticket, etc.
Since you seem to be able to use the web client, go to Settings, Account Profile & Security, Name, Email, Phone. You should see a place to set your phone number.
7 REPLIES 7
fidelvega
Hello, I had the same problem some months ago without Anu Arlo solution, you have to create a new account and hard reset your smart hub and start again with a new account, that's is the solution, I lived through the same story.
regards
Fidel
rlmckeen
I have to be able to access the account in order to reach these settings. Since I do not receive the verification code at the email address set in the account, I can't actually get in.
This is not a solution. I need Arlo's 2FA system to actually send the verification email. I know that Arlo's email addresses are whitelisted because I get advertising emails from Arlo. They seem to be able to manage to spam my email address but not provide a simple verification code, or get an engineer to respond to a case.
Case Number: 45186822
This has been going on for nearly a month. If someone could remove the 2FA requirement so I can access my account, that would be the most useful outcome.
rlmckeen
I'll give this a shot. If I can't get back into an account or get a hard reset to work, I have several hundred dollars worth of broken, non-functional, unsupported equipment that can go into the trash.
I'll never buy this again.
edit- actually, this won't work. I can't re-set the base station with a new account if I can't remove it from my old one. Why hasn't an Arlo engineer addressed this problem yet?
I'm tagging the mods - @BrookeN , @ShayneS , @JamesC - in hopes one of them will arrange for support to reach out to you.
Dano1763
Any solutions...I have the exact same issue. I can login, but then get sent to the 2FA screen, two 3 old iphones I no longer have (for Arlo push notifications), and a Yahoo.com email address are listed. But Yahoo, no matter what is tried, will not receive Arlo emails, so no six digit code, and no access to any Arlo settings.
Before I trash the whole system...help!
BrookeN
@rlmckeen I received your message. I have reached out to support, they will be contacting you as soon as possible.
@Dano1763 you can send me a dm with your phone number as well as a good time to call. And I will have support reach out to you.
