No more recordings???
I have had 4 cameras for 8 years and now my arlo app says I can't have any recordings without a paid subscription. I don't need 60 days worth. I'm fine with just the seven. Is it really over? Is there a way to be grandfathered in to what I've had for so long?
Message 1 of 2
2,708
Which cameras? The originals use four CR123 batteries and the Pro 1 and 2 cameras use a rechargeable battery (remove the battery and look for a label in the compartment that has VMCxxxx). While the cameras are EOL, they still work and have the free 7 day plan. You may have some premium features enabled that require a subscription so try turning them off (activity zones, Smart Detections, etc.).
Message 2 of 2
2,698
