q camera setup
  • 3241 Views
roberthacker1
adding a second camera.  after the camera sees the bar code and makes the chime sound there is no further progression and then a two tone buzzer sounds and says can't connect...My other camera is working fine and this one has previously been set up and worked fine.
do a reset on the Q camera and then attempt to resync.
( hold reset for about ten sec till the front led blinks amber )
Misho
I tried the same and did the reset but not connecting at all
contact Netgear Support
