arlo security camara setup
  • 1 Reply
  • 2963 Views
Lyndagragg
We got as far as getting green lights on the base station for the two left LEDs. On the Netgear R6700 router the LED indiating where the cable is plugged in is amber. We restarted everything and went through the set-up procedure with the same result. On the Netgear router website, under the attached device tab a device which I presume to be the Arlo base station, shows up (we have no other wired devices). What do I try next?
If the two left lights are green, then u have power and Internet,
The third from left is a sync camera....you have to sync the cameras to the base.
Quick push on the base sync button ( don't hold) then 3 sec or so later push the cam sync button
After the cam syncs u should have 3 LEDs green from left
