arlo q vmc3040-BRIGHT LIGHT
Why does this one out of 3 cameras inadvertantly display a bright pinkish light sometimes solid sometimes blinking for NO particular reason.
problem seems to follow the camera seemingly not about distance from router
I can access the camera when the light is on.
Can't see the image yet but a purple LED is a WiFi strength issue. Try moving the camera a bit to see if that helps. Swapping cameras around can help isolate the issue to the camera or the location.
Arlo Q
