Why y Arlo Q records are not available in the bibliothech?
  • 2 Replies
  • 2876 Views
poco06
Hello,
I have an Arlo pro with 3 cameras and have added an Arlo Q.
All are defined to record video when motion sensor detects a movement.
The issue I have is that for the 3 Arlo pro cameras, the record is available in the "bibliotech" tab, but for theArlo Q, I can only display it when I'm getting the mail with the link to display the video in the https://my.arlo.com/#/viewShared/ folder.
Is there a way to place the recorded video of the Arlo Q in the bibliothec?
Regards
Pat
The Q should be recording in the Library.... are you sure you don't have a filter on ??
poco06
Hi and thanks for your answer
Yes I'm sure nothing is recorded in the librairy (no filters). If I record life, then it is in the librairy but each tile the video is taken afer a detection, nothing is in the librairy. I just can display the video thanks to the link in the mail and I'm redirected to an url like https://my.arlo.com/#/viewShared/
Regards
Pat
