Why isn't 5V power to Arlo Q working?
I have my camera 6 m from the power supply which is an USB charger (5V/2,1A). The cable dimension is AWG 20 and a use only +5V and 0V. In this case the camera doesn´t work. Anyone who knows why?
PS
If I connect with a short standard USB cable it works fine.
Hi @Malmokalle
Ok, will do that. Thanks!
I asked, but the answer was that it was not an "Arlo issue" because I don`t use a Arlo standard cable.☹️🙄
Arlo Q
