Where to purchase wall mount for Arlo Q?
Hi,
I purchased the Arlo Q webcam a couple of years back and I originally had it standing on something. Recently I decided that I wanted to mount it on the wall, but I am unable to find the mount plate for the device. I tried searching on Amazon and Arlo's website to see if I can purchase a spare wall mount, but I did not come across one. Can this be purchased on the Arlo's website? If not, can it be purchased on Amazon and if it can which item is it?
Thank you for your help.
Use the Contact SUpport link at the bottom here to see if they will send you a plate.
Arlo Q
