What is the Arlo Q detection range?
  • 1 Reply
  • 1419 Views
craig9000
Anyone getting more than 15 feet detection range on their Arlo Q?
The FAQ says detection range is 50 feet:
How well does motion detection work on Arlo Q cameras?
Arlo Q cameras can detect motion from as far as 50 feet away. In addition, you can create up to three motion detection zones so that motion in detected in specific areas within the camera frame.
Yes,...
Have a Q cam looking thru andersen window ( double pane ) and get over 50 ft detection. ( street traffic )
As the cam is pixel change detection over the normal PIR this is about max range at 50ft+
What is your sense level set at ( and are you adjusting it in the mode you arm with )??
don't use zones on this cam
Yes,...
