This widget could not be displayed.
VMC3040 setup unsuccessful
  • 9 Replies
  • 5190 Views
GeorgK
After the purchasing setup used to work smooth.  I did not use the cameras for 6 months and can not reconnect. Restarted, deleted, reset. Does not work. The camera makes a sound but device (telephone or pc) can not find the camera. Setup unsuccessful. I have two cameras. Maybe need to update the software but how without a connection?
BTW I tried to contact the support by live chat. Bad day. It shows a message
Uncaught TypeError: Cannot read property 'setParam' of null throws at https://www.netgear.com/mynetgear/arlo/ContactUs/Chat.aspx?l=en:8:12156
GeorgK
Problem solved. Can lo in at my friends house.  Updated device. Back home. It works. Thank you for your help.
9 REPLIES 9
GeorgK,
Is the camera still claimed on a previous account?
GeorgK
Yes, I did not change anything with the account
Okay, lets start by taking a look at your account. Log in to your Arlo account and navigate to Settings > My Devices. Do you see any devices listed there? If so, remove them.
After that, power on the camera and press and hold the reset button until the camera reboots. After the reboot, attempt to claim the camera again by logging back into your account and clicking "Add Device" and selecting Arlo Q. Do you still experience an issue? If so, what error message are you seeing?
GeorgK
Thank you for your help.  I don`t have any devices listed. I tried to add
I have the message
we`re sorry,  arlo is not available at the moment, please try later
I will do
GeorgK,
There was a short period of time where some users were experiencing this issue yesterday. Are you still seeing that error message?
GeorgK
Yes, I will try today again and give a feedback
GeorgK
Hello JamesC
today I tried to do it again.  All setup procedures.  Amber light, blue light, chimes OK.
After that says, it takes very long please wait, and proposes factory reset.
After reset setup same again.
After several times tries says the server is not available what I   don`t like very much.
Webpage not available
https://vzs3-prod-common.s3.amazonaws.com/static/v2/html/en
Very frustrating
Try logging out and back in. I find that sometimes lets you see that the camerais actually there.
GeorgK
