VMC3040 Solar Panel Charging for Arlo Q
  • 1 Reply
  • 2716 Views
mrdoug
I have a VMC3030 battery powered camera in a bird house enclosure under the eaves of my covered front porch.  I'd like to replace it with an Arlo Q in the bird house enclosure and not have to run A/C power to it.
Is there a solar or battery powered option available?  Otherwise I will need to run conduit from a power source 20 feet (up, across then down).
thanks
Not for the Q since it's intended as an indoor camera.  Whether the future release of the Arlo solar panel would work for you is unknown.  A Pro camera may be a better choice for this.
