Usage outside country
  • 4 Replies
  • 3017 Views
shazrahath
Befor i Buy
Hi, I am planning to buy an ARLO Q from UK which i am planning to install in India. Can I operate it from this distance and what all thing to look into.
Check what power supply you have in the location you're setting it up as the adapter is a USB out put from AC
Apmost any place that has Internet upload over 1 Mbps will work on the Basic levels but higher plans may/may not be available in some countries.
shazrahath
Just clear it, so is it possible to view the video feed from here. Do i need to got there to set it up with my iphone or set it from here and send it to India.
You should be able to just set it up in India since it needs to connect to the local WiFi anyways.  Where it gets set up has no bearing.
The only exception to above is if you want a higher level of service.
If you set it up in a country not supporting higher levels, you can't upgrade,,, if you set it up in country that supports higher levels of service, it's my understanding you'll be able to upgrade reguardless of running location.
