Reseting my Arlo Q connection
  • 1 Reply
  • 2125 Views
Scottie_GB
Hi
I have just set up my camera at a relatives house to test it after buying it today.
I now need to set it up on my home router, is there anyway of keeping both connections, so if I can switch between locations or do I have to delete the first router at the first location before I can set it up at the camera on my home network?
As is anyone able to confirm how I can perform the set up please?
Scott
The Q is a bit different than the regular  Arlo .... In that it hooks to you wifi that is local at the time of setup.
If you move the Q to another wifi system, you'll have to sync it to the new system for it to work
There is no saving theold setup...easy to remove the device from the account and the resync
