Recommended add ons
  • 1 Reply
  • 1443 Views
Nporter04
I have two Arlo Q cameras in my home. I’m looking to add two more but would like wire free options since I want to put them in areas with no plug ins. Any recommendations on cameras that would still be able to interface with the ones I already have in the app?
Since your already using Q cameras, then yes and no with the Arlo/Arlo Pro/Arlo Pro2 cameras.
The arlo cams use a base which hooks via ethernet into your router... the cams talk only to the base unit.
Tho all the cameras Q and Arlo will appear in the same app/prgm, the Arlo cams with a base will have to be armed/dis arrmed on their own...you can not do a arming of all the cams in one set ( sort of like the two Qs you have now )
You would have to arm each Q and then the  Arlo Base ( cameras ).
remember the liimt on the free level or basic is a total of 5 cameras
