Night vision exposure issue
  • 2 Replies
  • 3237 Views
Tenler
I have Arlo Q positioned in such a way that one corner of the image shows the white surface it stands on.
When in night vision the white surface reflection is the only thing visible (everything else is black). How do I manually adjust or tell the Arlo to use center for exposure level?
pan and zoom will not solve your issue...
You must adjust the camera ( longer mount maybe ) so the IR does not reflect off the mount or walls.. there is no center weighted iris adjust.
It would be worth trying to set up a Pan & Zoom setting for the camera. I don't know if tht would solve the problem but it's worth a shot. Check Settings, My Devices, your camera, Video Settings. Be sure to save your setting.
