Newly defined activity zones can not be saved
  • 3533 Views
metsch
Newly defined activity zones can not be saved. Movement detection is carried out in the "Everywhere" sector.
Hula_Rock
Prodigy Prodigy
Prodigy
Just to make sure.... are you hitting the save button after each one is created.  I just redefined my 3 zones and saw them all in three defined colors.
metsch
I have saved the zones. Furthermore, the entire visible zone is recordet.
Greetings
Don't forget that once you create the zones you also have to enable them in your modes/rules.  By default the whole scene is used unless you specify the zones in your rules.
