My Arlo Q Will Not See Wifi Network
  • 2724 Views
DLTII
Just got a new Arlo Q. Following the setup procedure the phone app never sees the wifi name. It shows <unknown ssid> there is no option to input the SSID. I have uninstalled and reinstalled the phone app. Rebooted the device a few times.
Tried to put the password in as it is, no luck.
Do it on a computer with web broswer like Fire fox... SSID must be added during install
https://arlo.netgear.com/
DLTII
I'm sure it does need input during install. It is not an option.
DLTII
Got it. what I found is doing the setup with the phone app does not work. You must create the account on a PC. Then you get the full setup menu
