Loud thump daily
- Email to a Friend
https://arlo.netgear.com/hmsweb/users/library/share/link/98B23024A28E9B37_201803
- Email to a Friend
I am not certain what type of structure your devices are installed within, but I would consider adjusting the microphone sensitivity or simply turning off the microphone activation if that would not interfere with the manner in which you are using the devices. It seems reasonable to me that accoustics wherever the devices are installed and/or the placement of the devices could be involved, and I tend to believe this is more likely than there being an issue with the device microphone-once you are able to exclude noises from neighbors and those from outside.
- Email to a Friend
Have never heard this before in all the time I've been working with Arlo ...that is strange.
There was an issue with the mechanical filter on one series but that was corrected and there is no mechanical filter that I know of, on the Q
I would recommend you contact Netgear support and see what they have to say
Arlo Q
