I have a new arlo q . I have purchased it for securing a holiday home
  • 1 Reply
  • 2041 Views
malderton
I have an arlo Q in an area where I cannot get normal broadband and hope to use it with a  netgear sim only router.  I propose to purchase 5GB of data per month.  Will this be sufficient for say 10 No 30 second  clips per day at 1080 resolution.
Assuming I do not connect other devices for example my computer do you think this will be sufficient data ? At present I propose using only 1 camera
Whien the Q cams record at 1080, the average 30 sec file is about 3 +Mbs...
or 1Mbs per ten seconds ( +/- ,depending on light condition )
So 10 clips would be about 30 Mbs....you can do the rest of the math. 😀
Keep in mind this is record only...if you view it from the same location, it would be double ( does not double if viewed from another site )
