How do I adjust Arlo Q recording length
  • 1 Reply
  • 3159 Views
TBerry
I have read several posts in the community, however, what I read does not match what I am seeing when I attempt to follow the instructions.  Arlo Q using iOS devices.
It may be the ios app causing trouble still...thought the last release fix the problems.
Have you tried a PC at   https://arlo.netgear.com/
But reguardless of the small diferences, it's basically the same way...
Go to the mode you using on the Q and edit it;
MODE >  ">" to edit, pick cam if more than one, hit EDIT
drop down to RECORD VIDEO and  ">" to edit
adjust slider bar for time, use the BACK on page
bottom of (previous) page is SAVE
