  • 2 Replies
  • 1457 Views
Jagmd3
Severa alro Q's in different locations as well as other Arlo cameras, essentials and pros.
Only the ArloQ's drop from the network?
They are older than the others, are they trying to get me to buy newer cameras?
Streak2
Master Master
l also run an Arlo Q and it's working no problem.
Remember that the Q is connected directly to WiFi as opposed to a hub.
Could there be a wifi problem at the Q location?
Worst case remove and reinstall your Q.
Jagmd3
I have 6 Arlo Q's on 3 different networks and they all dropped at once.
Come to find out they were all upgrading the firmware! At once!
I only found out by looking at the phone app, on the computer connection it doesn't tell you what's happening.
So I'm up and running again!👍🏾
