Can I download the 24/7 CVR
  • 1 Reply
  • 2940 Views
leeseinmaine
I set up my Arlo Q to record at night, as my car keeps getting vandalized.  Unfortuantely, I park in the "shadows", and the motion doesn't always catch the movement in the shadows.
I know I can download the blips of video recorded by the motion sensor, but is there any way I can download the entire night's video?
If not, then is there a way to "watch" the entire night in fast forward mode?  I have tried moving the time ticker slowly, but the buffer skips over the frames.
No way to fast forward the CVR timeline.  You can use 3rd party sctreen capture software to capture the CVR review but that would be at 1x speed so a long time.  It would be better to review manually and then use the screen capture software for the important parts.  That way you can skip over the uninteresting parts and concentrate on the action when it occurs. For best quality, be sure to capture when CVR is full-screen.
