Camera keeps resetting. Boots up camera and shows orange.
My camera keeps resetting itself. It boots up camera light turns orange, then blinking orange, then makes a sound a resets.
It sounds like a hardware problem but first remove it from Settings, My Devices and perform the camera reset. Then try syncing it again. If that fails, use the Contact Support link at the bottom here.
Arlo Q
