ArloQ is it possible to eliminate the panel on the bottom that shows icons
  • 1246 Views
ArrayQ
When viewing live feed online (i.e. on laptop), is it possible to eliminate the panel on the bottom that shows icons (i,e, where you can turn on full-screen mode, adjust the microphone volume etc)? I have the camera angle just where I need it and can fit everything in BUT now I find that a chunk of screen is not usuable due to this icon panel
No but full-screen eliminates that row.
ArrayQ
Thanks, unfortunately that doesn't help in my situation as I need to be able to have other windows visible at the same time. Are there any other options- can it be moved to another part of the screen?
Nope. What you see is what you get.
