ArloNetworking. ServerResponseError error 1.)"
  • 10 Replies
  • 5280 Views
Mehdiua
I get the following error after assigning a name to the device, just one step before activating the device. (many times after factory reset the device)
"Error occurred
The operation couldn't be completed and i can not claim it.
(ArloNetworking. ServerResponseError error 1.)"
i also tried to onboard it via “my.arlo.com” on a computer browser, but at the same step after i have given a name… it just logged out and the page jumps to “Sign in” page.
Also important to know:
“i do not use Mesh on my wifi”
“tried with 2.4 and 5G wifi”
“changed SSID and pasword”
“ i do not use any specific characters on my wifi SSID or password “
“ i already have two more Arlo Q on my account”
“tested on another Arlo account“
I purchased it online and spent several hours attempting to set it up without success. In an attempt to troubleshoot the issue, I reached out to the camera's previous owner and asked them to remove the device from their Arlo Secure app, which they kindly did. However, even after this step, I still haven't been able to get the camera to work.
10 REPLIES 10
ShayneS
Hi @Mehdiua
Are you still experiencing this symptom?
Mehdiua
@ShayneS unfortunately yes!
i tested with another router still same error!
ShayneS
Have you tried factory resetting the camera?
Mehdiua
@ShayneS
Yes i have tried to factory reset many times! same result!
Just to be sure, did you hold the reset button until the camera clicked?
Mehdiua
@jguerdat
Yes i did!
It sounds like the camera may be toast unfortunately.
Mehdiua
@jguerdat
i don't know how its possible! i bought another Arlo Q last week! onboarding goes well, camera detects by app and serial number shows until i assigning a name to the device and
Error occurred
The operation couldn't be completed.
I tried bouth camera in a diffrent place with another modem, wifi and acount, same result.
ShayneS
Does this only occur with your newly purchased Arlo Q?
Where did you purchase this device from? was it used by chance?
Mehdiua
both!
I bought them used and the owner has removed camera from his account!
