Arlo q sensitivity for nursery
Using the arlo q as a nanny cam in baby's room. Its only recording motion/ audio, and I'm having an issue finding the correct sensitivity level for the audio. We have a white noise machine that plays in there sometimes, is there any way to adjust it so it doesn't pick up the white noise machine but picks up the baby crying and starts recording? When I set the sensitivity to 80 percent for audio it just continuously recorded when the white noise machine was on. If set low it doesn't kick in recording when baby cries. I'm guessing we just need to not use the white noise in there. thanks!
to the mic, the white noise and the baby crying are prob seen as the same...
You would be hard pressed to set it once for both levels of noise
Arlo Q
