Arlo app login paacode
  • 1 Reply
  • 2021 Views
TheGuy123
Arlo app login is so annoying.
Touch ID often fail and need to enter the full password. Is there way to set up 4 dig code or just avoid the password for login?
No. Just take your time using your fingerprint (I use it and don't get my thumb positioned properly all the time). That's a user problem, not Arlo.
Or turn off fingerprint and the app will automatically log you in.
